jenomze to jsou uplne obycejne desky s kteryma sis asi moc nepomohl
SAXOKLUBÁKZaložen: 14. 07. 2010Příspěvky: 174Bydliště: Uherské Hradiště
obyčejné nejsou pokud omp nekecá.... koeficient 0,4 má například ferodo ds 2000
OMP Road & Sport Brake Pads: The new OMP brake pads R&S (road and sport), suitable for road use, are made from a friction material, asbestos free and have the following characteristics:
COMPOSITION: thermosetting fibres and resins.
FRICTION COEFFICIENT: 0.40
FRICTION STABILITY: steady also when temperature varies within a field between 100 and 600degrees C
ANTI-FADING CHARACTERISTICS: excellent and combined with a low wear rate.
APPLICATIONS: these brake pads were developed for being used with front or rear brake discs for a very wide range of car models. For their special resistance to stress and for their efficacy they are also suited for light competition use.
po načtení vesměs záporných reakcí na tyto destičky (nečekaně vadnou, nestálost brzdného učinku, malý výkon) sem objednávku zrušil a objednal komplet brzdy Ferodo.... takže jdu radši do jistoty
